Colliding particles with a static removing geometry
   2225   6   2
Hello all.
I was just testing the collision between a static removing geomerty and particles.
At frame 50 I remove half of the sphere but soon as I remove it, particles explode queerly!
I attached my test so you can see what happens at frame 50.
Let me know if this problem happens for you as well.
Thanks a lot in advance.
Dynamic Removing Collision Geometry.hip (319.6 KB)
I think the changing point count might be throwing off the deforming-geometry sourcing for the collider... it's more for actual deformation, not partial-deletion.
Try having each half be a separate, non-deforming static object, then just "switch off" the top one... not sure if there's a more elegant way, I've used a Switch DOP.
Dynamic Removing Collision Geometry__edit.hiplc (321.5 KB)
Dan Wood
Vortex VFX Ltd
VortexVFX
Thank you so much.
But the problem is that if you want to delete the primitives of the geometry dynamically during the simulation, this method won't work anymore.
I know that we can use volumes instead but I'm curious to know why this happens for surface colliders.
You have to organize the collision geometry so that when you are deleting part of geometry the rest part would have saved
points order.
Edited by vicvvsh - April 10, 2025 02:16:20
Dynamic Removing Collision Geometry_01.hipnc (217.2 KB)
Why do particles explode when I remove part of a collision mesh at a specific frame?
Thanks a lot.
Sorting point numbers solved the problem.
MiloStorm
As vicvvsh has mentioned, changes in point numbers cause the simulation to break!
