Just detailing some of my experiences seeing if houdini would work on the Surface Pro 11 (Snapdragon X Elite) under emulation in Windows 11.
Out of the box it doesn't work, not for the ARM or emulation under PRISM reason as I thought would be the case but actually due to graphics. This is due to:
- Qualcomms GPU drives for Adreno are terrible, they support Direct X 12 and supposedly Vulkan but thats new.
- So no Open GL support, or Open CL support, which is not helpful!
- Microsoft have a compatability shim in the store that translates Open GL, Open CL and Vulkan (yes even though the driver does Vulkan supposedly) to DirectX12. This is available in the windows store.
- You can get native vulkan support by either removing the whole compatability pack or by deleting the dzn files in the folder (I can give details if anyone wants).
So out of the box Houdini crashes as the OpenGL shim does something it doesn't like. If you delete the files to get vulkan on the driver working it still doesnt work, I'm not sure if its because of the driver or if it's because it still uses some OpenGL things.
You can get it working however by using Mesa llvmpipe to do software open GL rendering, but the viewport is pretty slow. There is probably a configuration to get it doing open GL via DirectX12 or Vulkan (zink), but I couldn't figure it out.
To do this get the x64 (not ARM) mesa opengl.dll file and drop it in the houdini bin folder, set the environmental variables for the mesa driver and it should work. I haven't tried too much due to the viewport speed but will do so and update at some point.
There is also the Angle on Vulkan that does OpenGL ES which may be helpful, but I haven't tried yet.
So today I wouldn't reccomend it under windows, there is probably better luck under linux as the freedreno driver does do OpenGL but I think x64 emulation isn't as good.
Suprisingly though it's not because of ARM but OpenGL, which I wasn't expecting. Improvements to the Microsoft shim or the Qualcomm drivers may solve this though, or there might be some houdini env variables that may help.
Houdini on Windows 11 ARM (Surface Pro 11)
3909 3 1-
- user1111
- 6 posts
- realjanehuang
- 2 posts
- phonebreaker
- 6 posts
thanks for sharing user1111
realjanehuang
Documents/houdini20.5/houdini.env/(RMB/Edit in Notepad)
Copy and paste: libgallium_wgl.dll & opengl32.dll
into bin folder
realjanehuang
LIBGL_ALWAYS_SOFTWARE = 1
into bin folder
- https://github.com/pal1000/mesa-dist-win/releases [github.com]
- mesa3d-Version-release-msvc.7z
Edited by phonebreaker - Dec. 22, 2025 08:12:47
- phonebreaker
- 6 posts
Hi everyone,
troubleshooting:
- houdini21 will not run
- houdini20 bug: no Curve render in viewport
- Network View: ignores cut wires
If it wasn't for the Curves, then it would be a neat notepad for vex and look ups. OP did you have any luck with the other viewport renderings that u suggested?
troubleshooting:
Edited by phonebreaker - Dec. 22, 2025 07:20:26
