Console Messages when compile MPM "Failed to read file: ..."
   1560   2   0
Houdini 20.5.684
Win 11
When I use the preset, for example, "MPM Configure Water Glass":
When compiling the OpenCL Kernel, this type of message appears on the console:
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-77b715.d
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-527c59.d
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-a94260.d
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-92b185.d
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-e91ac6.d
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-fc16ae.d
Failed to read file: C:\Users\***\AppData\Local\Temp\dep-b60961.d
This doesn't block execution.
Do you know where these messages come from, please?
Thanks so much.
I keep getting a similar error when working in cops
Failed to read file: C:\Users\travi\AppData\Local\Temp\dep-0a64a4.d
Failed to read file: C:\Users\travi\AppData\Local\Temp\dep-77ac4c.d
Failed to read file: C:\Users\travi\AppData\Local\Temp\dep-6cc2f6.d
Failed to read file: C:\Users\travi\AppData\Local\Temp\dep-695435.d
Failed to read file: C:\Users\travi\AppData\Local\Temp\dep-78fc75.d
Failed to read file: C:\Users\travi\AppData\Local\Temp\dep-415eea.d
I'm having the same issue. Not sure if it's affecting the performance, seems te be happening when the compiling OpenCL kernels is in progress.
