Karma Texture Baker Height maps without negative values ?
   450   0   0
I tried baking high-poly details onto the low-poly UVs. Since the low-poly model was generated from the high-poly model using polyrebuild, I used the UVmatch mode.
While baking the Height map, I noticed that even the concave areas resulted in positive values.
Did I miss some settings?
Edited by chongsong - Sept. 2, 2025 01:34:16
