Labs Exoside QuadRemesher HDA fails to properly validate the
   1378   3   0
I'm not sure whether it's an issue with my setup or a bug, but starting from version 20.5 to 21, the Labs Exoside QuadRemesher HDA fails to properly validate the license. The only way I can get it to work is by completely removing the version bundled with Labs and manually downloading the official version. However, every time Labs gets updated, I have to repeat the whole process.
Does anyone have any suggestions? Thanks in advance.
For anyone else encountering this issue: I found a workaround. In the Asset Manager under the Configuration tab, enable OPlibraries Files and uncheck "Give Preference to Definitions with Latest Date." Then, edit the relevant local OPlibraries file to place the official HDA path before the Labs path.
i have the same issue, but iam absolute new to Houdini. I worked only with Blender before. Ok, i found the Assetmanager and enabled and disabled the things you are explain, but i don´t understand what you mean with edit OPlibraries wich file i must edit and what should i write into it?
gopper0815
Assuming you're using a Windows system, the file can be found at the location shown in the screenshot. In addition, you may also need to set the priority for duplicate assets in the Asset Manager.
Edited by guan9287 - Oct. 12, 2025 20:29:18
