TrembleFX - Procedural Noise Generator for Houdini
   401   0   1
BLACK FRIDAY SALE! FIRST 25 CUSTOMERS GET 25% OFF - USE CODE * PRO10 * AT CHECKOUT
Get it here TrembleFX [shirmanor.gumroad.com]
TrembleFX are a pair of OBJ and SOP HDAs that generate CHOP-based motion noise with one click. Add natural sway, vibration, drifting movement, or full chaotic shake to any object, camera, or piece of geometry without touching a keyframe or a CHOP network.
Fast + Artist Friendly
Pick a preset, toggle which axis you want to move, and tune sliders like Amplitude, Speed, Harmonics, Smooth, Multiply, Noise Type, and Random Seed. Everything updates instantly in the viewport.
Preset Library
Includes a wide range of motion styles:
Sway, Vibrate, Pulse, Drift, Run, Twitchy Rotation, Chaotic, Security Cam, Steady Walk, Steady Crane, Ease & Hold, Gallop, Jackhammer, and Custom for full control.
OBJ + SOP Workflows
OBJ (driving node): Perfect for cameras, props, characters, environment assets, or handycam-style movement, simply apply it before your object.
SOP (driven node): Offset animations on individual pieces inside For-Each loops using random seed, speed or whichever value you like, use it manually or apply to scattered objects, debris, or mograph-style setups by applying it after your objects.
Looping + Stylised Motion
Use clean noise or sine modes for:
  • Loopable animations
  • Idle cycles
  • mograph motion
  • Subtle realism or stylised jitter
Fully Editable
TrembleFX are HDAs with a simple to follow chop network inside. If you want to go deeper, open it up and customise the CHOP networks, build new presets, or expand the logic.
Versioning
TrembleFX has been tested in Houdini Indie 20-21+
If you are a HoudiniFX user and this does not work please get in touch.
Edited by SMFX - Feb. 2, 2026 18:30:51
