Button parameter to change the input of a switch node
   326   2   1
Hi there,
For a tool that I'm building, I need to have a switch node (with two inputs) switch from the current input to the other. This has to be driven by a button press on my hda. Im not good with python or hscript but i tried everything i could think of (python callbacks on the button, python modules in the hda that the button refers to, hscript links, trying to make a button increment an integer and have the integer parm toggle a switch-if node...) but nothing works. I know, a button parameter is not intended to drive a switch node but I'm trying to hook it up to a "renderexec" button of a renderrop.
Thank you guys in advance
Hi read the current value of the switch input parm and set a negated value each time you press the button. Result is same as using a toggle.
button_switch_state.hipnc (75.6 KB)
vikus
That works like a charm, Thank you so much.
