TOPs rendering with slapcomp
   350   1   1
I have a project where I need to render out a bunch of assets in a studio environment.
I'm using TOPs to load GLTF files, setup render paths and commit the renders.
The problem I encountered is: How do I include the slapcomp into the final output?
I want to avoid (if possible) first rendering out exr files to disk and then running those through a cop network. I would like to apply the slapcomp right when it renders and just output the final composited jpegs.
I have prepared a hip file for this forum where instead of loading GLTFs I just randomly rotate the test pig geometry and give it random colors. The output file name is also a random number. I tried to solve my problem by targeting a rop image output in the slapcomp but that doesn't work.
Here is the video of my setup/problem:
Edited by koko_ze - March 2, 2026 11:06:16
batch_TOPs_slapcomp.hiplc (935.8 KB)
I got the solution from a Think Procedural discrod serverfrom a user "sevenseventrheetwo".
I needed to define the slapcomp inputs and outputs in the "USD Render ROP > Husk > Slap Comp".
In my case I just needed the holdout shadow pass:
Now I just need to figure out the OCIO settings.
Edited by koko_ze - March 4, 2026 03:09:24
batch_TOPs_slapcomp_V2.hiplc (927.0 KB)
