The new bakegeometrytextures node not rendering in COPs
   428   0   1
I am trying to use the bakegeometrytextures node to resolve an issue I have with my scene.
I created a copnet at the object level and added the bakegeometrytextures node.
As you can see, it works in the scene view, but when I render it, the normal map is not rendered. I am using Redshift, but it also does not render in the Houdini Render view.
Is there a setting I must change to render this scene correctly?
Attached is an image and an example file.
Edited by iso - March 3, 2026 12:01:11
Example.hiplc (739.7 KB)
