Short version: Is it possible to mirror a walk cycle in Houdini without using APEX?
Long version:
I'm learning the basics of Houdini, and I'm right now trying to make a very basic walk cycle with a very basic rig.
So far, I've been rigging entirely with KineFX (as in Rig Pose plugged into Bone Deform) without using APEX at all. I've been learning Houdini this way for a very simple reason: I think I may hate APEX. (Sorry.) As a Blender vet, the nonlinear nature of the KineFX rigging introduces so many possibilities that weren't there before, and the way things connect with the KineFX SOPs is, for whatever reason, incredibly intuitive to me. But, whenever I touch APEX, it's like hitting a brick wall! (You have to build the half of the rig in KineFX anyways (skeleton node, biharmonic capture, etc.), so why bother with APEX? Where KineFX uses nodes in a nonlinear way (make the skeleton over here, make the IK joints over there), APEX puts the nodes in a straight line (autorig component into the next autorig component into the next autorig component into the...). 90% of the APEX tutorials focus on autorig components that have since been depreciated into better but largely undocumented autorig components. KineFX does IK by selecting the bones you want in the chain, APEX does IK by you first adding tags that you have to look up or memorize every time. Etc. etc. etc. I know there are pluses to APEX (it's faster, it's designed to make sense if you're used to Maya), but I've been taking an approach of learning KineFX, until I get good enough at KineFX that I can see its weaknesses and see what I have to gain from APEX, and THEN switch to APEX. For what I'm doing right now, APEX seems like a lot to learn that just doesn't think the way I do for not much reward. So, if possible, I want to stay in KineFX for now.
Unfortunately, I've encountered a very big problem. In a walk cycle, the second half of the cycle is a mirror of the first half. In Blender, I would do this by copying the first half of the keyframes to the second half, and then mirroring all the poses. (Blender has a command to give the right half of the skeleton the mirrored equivalent of the left half's poses, and vice versa. Very handy.) In KineFX, this command ...does not exist.
What should I do to mirror the pose?
I already know a few options:
1) There's a RigMirrorPose node that does exactly what it says: it mirrors the pose. In theory, I could mix this node with the Timeshift node and the SkeletonBlend node to create my mirror second half of the walk cycle. In theory, this would be better than Blender's way of doing things, as the 2nd half of the walk cycle would now automatically update any time I made changes to the first half of the walk cycle. In practice, I've found that this results in very stop-and-start animations, because animating through so many nodes is throwing off the smoothing bezier curves that you'd usually get from the Animation Editor. Is there a better way to do this trick?g
2) The other way to mirror a pose ...is to use APEX. In APEX's right click menu when you're in the Animate state, there's a command to mirror a pose. That command isn't there in KineFX. In APEX ...it's that simple.
But accessing that one little command would mean I'd have to learn APEX and build a rig in APEX, something that constantly makes me feel like I'm rubbing my face against concrete. (In case it needs to be said, this is about what techniques make sense in the way I think, this is NOT a comment on the many, MANY amazing riggers who use APEX and the wonderful people at SideFX who made it. I'm sure it's great if you're not me. lol)
Like, dude. DUDE. I know APEX is the new thing that Houdini users are loving, but it's only a year or so old. Are you telling me that Houdini has lacked an effective mirror pose function for a decade plus? Like, I know APEX is better for performance and for Maya users, but are you seriously telling me it was missing pose mirroring? There has GOT to be pose mirroring in this program somewhere. ...right?
Please let me know if there's a way to do this without APEX. Even if the answer is, "No, just learn APEX", at least then I'll know to stop looking.
Thank you for any help you can provide.
How do I Mirror a Pose or Walk Cycle Without APEX?
377 0 0-
- AltCetera
- 1 posts
