help! why Houdini can't recognize NTFS harddisk in Mac OS X
   7467   5   0
Problem: when try to open a file in an external portable hard drive connected, that driver is not shown in Houdini's “open file explorer”.
Question: Why Houdini can't recognize NTFS external hard drive?
I'm using iMac with Mac OS X 10.6.3 under 32bit mode and the external hard drive is in NTFS fromat. I've already installed paragon NTFS so that my iMac can read and write files from and to this NTFS external hard drive.
Anyway, Mac OS can read NTFS partition, right?
Should work, but the disk won't show up in locations. Check the mountpoint in /Volumes/
thanks, hauerdie!
But can you tell me what “the mountpoint in /Volumes/” means?
Thanks again!
Have a look here. http://en.wikipedia.org/wiki/Mount_(computing) [en.wikipedia.org]
if you attach an external harddrive, it will be mounted by OSX somewhere in your directory structure. This is normaly /Volumes/, so if you attach a drive named ‘External’, it will be accessible at ‘/Volumes/External’ in your directory.
Understand! I can now locate my NTFS disk follow your suggestion.
Thank you very much!
hauerdie
if you attach an external harddrive, it will be mounted by OSX somewhere in your directory structure. This is normaly /Volumes/, so if you attach a drive named 'External', it will be accessible at '/Volumes/External' in your directory.
this is extremely helpful
