I'm going through the tutorial on the apprentice cd entitled ‘Image3D Volumetrics’. It cuts out near the end of part one so I missed some steps but part 2 does a little recap so I think I'm not missing anything. Anyway, the 3d texture generator doesn't work when I try rendering, I get the error ‘Unable to execute program: i3dgen’
Is this feature not available in Apprentice?
i3dgen
11154 6 2-
- tjvoll
- 14 posts
- cavedog
- 5 posts
I have the same error when I try to run the 3d texture generator in the apprentice edition - I can't seem to find any documentation stating that the feature is disabled. In fact, the i3dgen.exe program exists (and I can run it), just not from within the ROP section of Houdini Master.
I was trying to do the TechImage contrails demo.
Has anybody else successfully used the 3D texture generator from within the Apprentice edition?
- EigenAlex
- 639 posts
- cavedog
- 5 posts
Thanks for the reply Alex.
I didn't have the Houdini bin directory in my path - however, adding it didn't seem to help. I have confirmed that I have the right path, because if I run a windows cmd shell, and type ‘i3dgen<return>’ from my win2k root directory, it finds i3dgen.
That being said, I did find something a little odd - if I hard-code the path to my output i3d file, it seems to work: i.e. c
output.i3d will work, but $HIP/output.i3d will not. c
$F3.i3d works too, but not $HIP/output.i3d.
Seems like the $HIP variable is causing problems on Win2k.
$F3.i3d works too, but not $HIP/output.i3d. Seems like the $HIP variable is causing problems on Win2k.
- Stremik
- 170 posts
Try setting all of these system variables
(change paths according to your Houdini installation)
H C
Houdini5.5.151
HB C
Houdini5.5.151/bin
HFS C
Houdini5.5.151
HH C
Houdini5.5.151/houdini
HHC C
Houdini5.5.151/houdini/config
HIH %HOME%/houdini5.5
HIS C
HOME C
“whereever your HOME directory is”
H C
Houdini5.5.151HB C
Houdini5.5.151/bin HFS C
Houdini5.5.151HH C
Houdini5.5.151/houdiniHHC C
Houdini5.5.151/houdini/configHIH %HOME%/houdini5.5
HIS C
Houdini5.5.151/houdiniHOME C
The Things I Do For Love!
- EigenAlex
- 639 posts
- cavedog
- 5 posts
