H11 - Mac os X - Hqueue installation failed
   5625   3   1
Try to install Hqueue on snow leopard (10.6.4).
Works fine without Hqueue, failed with Hqueue option…
Any ideas ?
Here the console log:
27/07/10 21:03:37 installd PackageKit: Install Failed: PKG: post-install scripts for “com.sidefx.hqserver-11.0.446.7.pkg”
Error Domain=PKInstallErrorDomain Code=112 UserInfo=0x102805890 “An error occurred while running scripts from the package “Houdini.pkg”.” {
NSFilePath = “./postinstall”;
NSLocalizedDescription = “An error occurred while running scripts from the package \U201cHoudini.pkg\U201d.”;
NSURL = “#hqueuetar.pkg – file/localhost/Volumes/Houdini/Houdini.pkg”;
PKInstallPackageIdentifier = “com.sidefx.hqserver-11.0.446.7.pkg”;
For os x users: Seems to be a bug in installer.
Answer from sidefx:
Thank you for reporting this to us. We are working on a fix, (ID# 40741).
Good job anyway for H11 !
I got this problem too, the install failed with the Hqueue option turned on but installed successfully with it turned off, so as of build 581 the problem still exists, at least on Snow Leopard.
Just got bit by this one as well. Is there any way to install hqueue from the command line?
