Has any one had time to play with the pyro shader displacement,
i wonder how does it work, does it create noise on the volume, or does displace the voxel to create wispy fealing in the edges,
since the field say N i am assuming Normals.
any ideas?
Pyro Shader Displacement
15109 8 3-
- pelos
- 624 posts
- Alejandro Echeverry
- 691 posts
Mantra dice the voxels in to microvoxels (like other surfaces), then displace along a given vector; In this case you can define a vector from a 3d noise directly in the pyro 2.0 shader or calculate the gradient of the density to use that as a vector field (normal).
Here is an example file, unfortunately if you use any of the raytrace engines, the render gives nans and very odd artifacts.
- pelos
- 624 posts
- 691 posts
You can calculate the gradient from a fog also, if there is enough density change in the field (high dissipation fields) to determine the gradient, if not, convert to a sdf in sops with a volumesdf node then calculate the gradient.
- Nic Yiallouris
- 4 posts
- 691 posts
Now you can use all the nice vdb tools to do this!! Its waaayyy faster!!
- Nic Yiallouris
- 4 posts
- 691 posts
Here is the correction. Hope that helps!
- Nic Yiallouris
- 4 posts
