How I can download Orbolt's assets !?
   5631   3   2
Hi
I can't download any assets from www.orbolt.com.
I sign in with my Sidefx's Accouant and when I click on Download to get specify Digital asset from www.orbolt.com I get below error :
The address wasn't understood
Firefox doesn't know how to open this address, because the protocol (orbolt) isn't associated with any program.
You might need to install other software to open this address.
I check it on FireFox, chrome,IE but I get error again !
:cry:
Rabiee.Sadjad@Gmail.Com
Sorry to tell you this, but you have to have installed Houdini 12.1 first. It registers a helper application “orbolt_url” which handles download and installation of the orbolt assets.
If you already have done this, the locate orbolt_url in the dialog firefox shows you, and there you shoould go….
HTH
If you can't script/program it, it's no good at all !
What Houdini version are you using? The store needs Houdini 12.1.30 or higher.
Do you get a url handler window pop up in firefox? You can check if the url hander is associated with the store by going to
Firefox->Edit->Preferences->Applications
and check if you have ‘orbolt’ in the Content Type. If it's there set it to Always Ask.
Also, what OS are you running?
thanks
Adam
PS. Please stick to this thread and don't crosspost on odforce. It's easier to track things that way. Thanks!
Really Thanks Guys
My Houdini's version is 12.0.683 and this is my problem !
I should Install Houdini 12.1.
Thanks for your help
