Hi All,
I am trying to reproduce this houdini network.
http://vimeo.com/58231186 [vimeo.com]
Could somebody help me please
Thank you.
houdini flowmap
7082 5 4-
- matkin
- 9 posts
- vleermeneer
- 245 posts
Have you read the link that was posted on the vimeo?
You might get some ideas from this I suppose.
http://graphicsrunner.blogspot.tw/2010/08/water-using-flow-maps.html [graphicsrunner.blogspot.tw]
- matkin
- 9 posts
- vleermeneer
- 245 posts
I was thinking of using a displace along normal inside a vopsop and multiply the normals you've generated from the colors with the time, not sure if this is the correct way but there are many possibillities inside houdini thats what I like about it.
You only had information in the colors R, G, (B was empty) so I used color R for B also.
You could use this file to improve on, for example create better vectors for better flow.
For the looping part you could use a ramp parameter and manipulate the “time in seconds”parameter using hte spline type and set the values to 0, 1, 0 and use it to blend with the original normals using a mix node. (all inside of vopsop)
Or you could use a timeshift node with modulo expression.
I hope this helps!
I hope this helps!
- matkin
- 9 posts
- Reivax_1976
- 1 posts
