attribfrommap and file node questions
   6170   7   2
I'm doing mesh reduction on multiple objects using Houdini. I was hoping someone could help me get unstuck
Question 1:
I'm using an attribfrommap node that converts my grayscale map to weight values. This works great but I have not found a way to reload the texture. I have an absolute path to my Texture in the Texture path area but if I make a change to the texture on disk, I cant seem to get the updated texture into the attribfrommap node. Its like Houdini has the texture cached and doesn't reload it. (I also get old data if I switch to a new texture and then back to the old one)
Does anyone see what I am doing wrong?
Question 2:
I have a file node that is my geometry, I want to take the geometry file path from my input node, change it (changing the extension for example) and then apply it to another file node that writes the file out.
Ideally I want my network to iterate through all the file nodes in the scene amd go through the same polyreduce node and write out the files with a new name.
-Gisli
1. Does Update Textures in the Render menu work
2. Do you have a simple file as an example what you want to achieve.
Thanks for the reply, I hope this makes it clear what I am attempting. I've also attached a scene that is setup the way that I am trying to do it.
https://www.dropbox.com/s/i77zk8gado8728j/PolyReduceHelpRequestScene.7z [dropbox.com]
*edit
no, update textures from the render menu did not work
1) in textport type:
glcache -c
it should help
more info - here [sidefx.com]
2) take a look into the attached scene
PolyReduceHelpRequestScene.zip (356.8 KB)
Thanks for your reply. I looked at the file that you attached and it has given me an idea on how to proceed
The glcache command did not work, I have tried all methods of clearing cache in the software without luck. The only way I have found refreshing the input texture is to restart the software.
Yeah, seems it onlu works for shaders
only other workaround i've found so far is:
You can load image in COP's and reference it with “op:” syntax, file cop can reload images, its not ideal, but better than reloading Houdini
vopsMapRefresh.hip (172.9 KB)
For texture refresh you need flush texture cache and recook VopSop that reads image color data.
Look at example.
It would be nice to have that Force Update button with python script by default at least (until this update bug is fixed).
hou.hscript('texcache -c');hou.node('./calculate_point_attribute').cook(force=True)
forceImageUpdate.zip (49.6 KB)
Thanks a lot,
Clearing the cache and then force cooking the “calculate_point_attribute” works. Now I can make changes to my file on disk and re-load them via script.
Is there a way for me to force cook a node through the UI (right click menu or something like that) It would be nice if I'm making changes inside a network and I want to guarantee that there is no cached data still hanging around.
-Gisli
