Hi guys,
So I'd imagine this is a silly problem, but I have a rendering problem. I've got a bee - an OBJ imported from Maya. I've assigned a simple material with color map. The material appears fine on frame 1, but disappears on every other frame. The bee just renders pink instead. File attached. I've attached the original OBJs and texture as well.
Any help would be greatly appreciated!
Cheers
Cradders
Material only rendering on first frame
3122 3 2-
- Cradders
- 28 posts
- Sadjad Rabiee
- 1391 posts
That's because your Texture address path !
$HOME/Desktop/Tutorials/swarm/bee/scenes/beeText_v$F2.png
If you don't have sequence textures so you should just use simple numbers instead of $F.
Because your texture name is “beeText_v01.png” , So Mantra render your texture only on frame 1 ($F2 = 01 )
When you wanna choose your texture via “Choose Image” window , you should turn off “Show sequences as one entry” checkbox !
- Cradders
- 28 posts
- Sadjad Rabiee
- 1391 posts
