Render Particle Motion Vector
   4953   4   1
Hey,
I'm unsure if I'm even trying to do the correct thing. I thought I'd ask anyway!
I have a fluid sim, which contains a tank, an emitter and some collision geometry.
I want to be able to take the particle movement, at a given frame, and render it's direction/vector to a texture.
If possible, my end result would be a texture where if the particle was moving positive X, nothing on the Y, it would create a pixel with the value of 1.0,0.5. (The Z channel, would just write 0 to blue).
Any help / direction would be hugely appreciated.
Thank you!
Kieran
https://vimeo.com/104212383 [vimeo.com]
Exporting any attributes such as velocity or any custom attribute is so simple.
Just export it in the shader with same name , then use this name for Extra Image Plane in the Mantra node , In this case you can see your custom attribute's data as image in the different layers of your rendered image :idea:
Check attached project :wink:
JKVOut.hip (393.5 KB)
Rabiee.Sadjad@Gmail.Com
Thank you both, massively, for your help.
Joker386, the example is fantastic, thanks.
These both give me a huge amount of information I can work with!
Kieran Belkus
:wink:
