Balloon setup using apply relationship node in DOP
   3086   0   1
Hi all, i'm new to houdini and have a question about balloon setup, i successfully constrained the balloon to the root of wires,
i have several problems here.
1. right now it works but not “correctly” constrained ( all balloons are constrained to point number 0 using apply relationship node , but it should be balloon1–>wire 1 point 0, balloon2–>wire 2 point 4 …)
2. how to constrain the tip of each wire to each balloon ?
3. in single balloon setup there is an offset between balloon and wire tip at frame 1, how do i create the wire so that the tip point is located at the balloon bottom ? and also how to use an object as wire root instead of origin, so the root can be animated ?
thanks
current effect in gif animation:
http://gfycat.com/BleakEmotionalElephantseal [gfycat.com]
balloon_02_ask_odforce.hip (556.6 KB)
