Texturing tutorial?
   3282   6   0
Houdini looks awesome, but after going over the beginner training–
im still unable to texture, or render anything!
is there a simple - get started - texturing tutorial?
Lighting would be a help too.
thanks!
Correction, I found something older the other day. But the first node, he tabbed to texture with - DOESN'T EVEN exist in Houdini 14!
So for 14, please.
thanks!
Main change is that the VOP SOP have become Attribute VOP, thats where i was a bit baffled in the beginning.
Also if you see the sticky in the learning forum https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=27035 [sidefx.com]
I am just learning Houdini my self right now, but seems everything from H12 and up i still quite relevant.
Thanks much øyvind Fiksdal.
That's a huge help.
Hopefully that database is up to date? Unfortunately the first search I tried , I found:
INTRO TO RENDERING . Unfortunately- the link appears dead:
http://www.papicrunch.net/GC-houdb/index.php?collec=0&filter=gcsfield14%3DRENDERING&sort=idDSC&model=item&item=315 [papicrunch.net]
You should check Rohan Dalvi tutorials:
- http://www.rohandalvi.net/commercial/ [rohandalvi.net]
- http://www.rohandalvi.net/shader/ [rohandalvi.net]
- http://www.rohandalvi.net/textures/ [rohandalvi.net]
They are not free but are really good.
mantragora
Thanks mantragora. Yes, I saw those the other day, but they looked
a bit over my head. Next stop I hope!
