How can I create subnets with outputs inside a ROP network?
Thank you,
Caesar
no ROP subnet output node
2163 1 0-
- caesar
- 143 posts
- malexander
- 5301 posts
You don't need an output node for ROPs, because node connections indicate dependencies and not data flow.
When you wire a subnet as the input to another ROP (say, a mantra ROP), all the subnet's end-chain ROPs are added as dependencies to that mantra ROP. An end-chain ROP is a ROP without any outputs.
If instead you want to control which ROP is used as a dependency, use the Switch ROP to choose between the ROPs. If you want to choose more than one ROP, use merge ROPs to create groups and then a switch ROP to select from those.
