16.5.0.405 - Mantra keeps crashing - Fault Module Name: libVM.dll
   3476   4   2
Just bought the 2-year license and it's crashing on a simple sphere, yay.
Seen this?
Houdini 16.5.0.405
Windows 7 Ultimate SP 1 (6.1.7601)
Steps:
1. create Sphere
2. create Skylight
3. create Mantra object
4. hit ‘Render to MPlay’
5. MPlay appears for a moment and then Windows reports Mantra
Also crashes if we go to the Render View tab and hit Render.
File:
https://drive.google.com/open?id=1OFTlENWp9Dd-kOTkRSx0kIFUK6Mnq8-S [drive.google.com]
Crash Reports:
crash #1:
Problem signature:
Problem Event Name: APPCRASH
Application Name: mantra.exe
Application Version: 16.5.0.405
Application Timestamp: 5aa0f225
Fault Module Version: 16.5.0.405
Fault Module Timestamp: 5aa0e8ff
Exception Code: c0000005
Exception Offset: 0000000000018260
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 859b
Additional Information 2: 859bf404f15bc372d003674e7fba5a3e
Additional Information 3: f378
Additional Information 4: f378f661db6b360fe823276c9839be47
crash #2:
Problem signature:
Fault Module Name: libVGEO.dll
Fault Module Timestamp: 5aa0eef9
Exception Offset: 00000000001d2f3c
Locale ID: 1033
Additional Information 1: 171b
Additional Information 2: 171b976f0c3d13b5984bc212b26d5a40
Additional Information 3: 618a
Additional Information 4: 618a774870be06c4a9978542804ffd08
crash #3
Problem signature:
Fault Module Name: libPBR.dll
Fault Module Timestamp: 5aa0e996
Exception Offset: 0000000000007f45
Locale ID: 1033
Additional Information 1: d19f
Additional Information 2: d19fd233550073f4b15ef1498c5c2f9a
Additional Information 3: 47a2
Additional Information 4: 47a219b2f938e13d427a6c33b41cc11e
Could you post a HIP file that reproduces the crash, or does it only happen when created from a blank scene? Did you create a camera as well? The Mantra ROP normally errors out, (but doesn't crash), if there's no camera.
Thanks. The file I included contains a camera.
Support recommends we update our video driver, so will do so and see how it goes.
Your file renders fine on my system in Houdini 16.5.412 and using your camera, both in render view and MPlay. Had to create a mantra node though for rendering first. While I'm not a technical expert this might help to locate the problem in fact, perhaps system or driver related.
Hope this helps,
Arcite
Thanks for checking. SideFX Support thinks it's a hardware driver version… will find out tonight…
