Can you create a hierarchy of max objects?
   5716   1   1
been fiddling around with trying to fracture an object through an HDA in 3ds Max. the result should be a parent/child hierarchy of separate max objects, e.g.-
root
|-- object
|   |-- object
|-- object
|   |--object
but it doesnt really look like its possible through an HDA in Houdini engine? any recommendations on-
A- a way to create each fracture piece as a separate max object
B- link those in a parent child structure
thanks
This is not currently possible. If you can, please file an RFE with an example HDA!
