[Hqueue - COPS] - 8k and lower is fine on all machines, 16k and up it only renders at server
   1827   1   0
Hi!
Situation : 2 Indie licenses running on a local network.
When the COPS network is set to render out an 8k image or lower, it works on both machines. However, when it's set to use a 16k image as its base to comp on to, it will only work with Hqueue on the server machine. The other machine will give a “ERROR: The attempted operation failed. Error: Cook error in input : <Node name>”
Edit : it's specifically one file node that reads either an 8k or 16k image.
Anyone any ideas ? Thanks.
Edited by paleoPixels - July 15, 2019 01:59:44
with kind regards,
Bjorn
Houdini TA @ AAA game-studio
Freelance Houdini @ www.paleopixels.com
*bump*
Does anybody know if there's a way to get more info from a comp (composite driver) in /out/ …in a Mantra you can choose which error messages it outputs (verbose mode) but the comp node doesn't seem to have it
with kind regards,
Bjorn
