Hi all,
I can't get PDG to work with Hqueue on Ubuntu Linux 19.04, see the error below.
/shares/project1 is mapped to the shared network folder on the Hqueue server machine. I can access it from both the server machine and another machine on the network as the user hquser. Inside Houdini I can acces /shares/project1 just fine.
I tried logging in as the user ‘hquser’ instead of my regular username but the same error persists after opening Houdini and re-submitting.
All machines are using Ubuntu 19.04.
I'm at a loss at the moment why this is failing, any help would be much appreciated.
Error:
*** Starting:
/opt/hfs17.5.360/bin/hython /shares/project1/projects/_Paleopixels/projects/tops/pdgtemp/4433/scripts/top.py –report none –hip /shares/project1/projects/_Paleopixels/projects/tops/city_01.hip –toppath /obj/topnet1
Loading .hip file /shares/project1/projects/_Paleopixels/projects/tops/city_01.hip.
Cannot find file /shares/project1/projects/_Paleopixels/projects/tops/city_01.hip
File “/shares/project1/projects/_Paleopixels/projects/tops/pdgtemp/4433/scripts/top.py”, line 191, in <module>
hou.hipFile.load(hip_norm, ignore_load_warnings=True)
File “/opt/hfs17.5.360/houdini/python2.7libs/hou.py”, line 35874, in load
return _hou.hipFile_load(*args, **kwargs)
hou.OperationFailed: The attempted operation failed.
Unable to open file: /shares/project1/projects/_Paleopixels/projects/tops/city_01.hip
[Hqueue][Linux] [PDG] - Unable to open file error
2013 0 0-
- paleoPixels
- 26 posts
