Rizom Bridge Auto Cook not working
   2375   2   0
Is there a way to get the Rizom node to auto-cook? I'm trying to use it in a for each loop but can't get auto working.
Btw this is the model I am trying to uv. This is in substance painter, and you can see the smart masks are showing really bad seams because the Labs Auto UV result either gives me unacceptable seams or the whole mesh's uvs end up overlapping(all red in uv view mode) depending on the merge threshold/settings with not much of a happy medium. The rizom node does a great job but will only let me do one mesh at a time. There are so many parts to this model that I can't really see doing it manually if I don't have to.
bump
