Retrieve Camera location of a 2D image
1250 2 1-
- tosiho19
- 46 posts
- dhirst
- 6 posts
I'm not sure of a Houdini only solution, but I've used fspy with some success https://fspy.io/ [fspy.io] It's not automatic and you will need a image with a certain number of parallel projection lines to help calculates the camera position. The results can then be imported to Houdini via blender plugin https://github.com/stuffmatic/fSpy-Blender [github.com]
Sorry seems a bit convoluted, but it can work. As generally most camera tracking solutions are from a moving images.
Other areas worth investigating are photogrammetry solutions like Meshroom or Zephyr (camera export not free) or Alice vision Labs plugin AV_photogrammetry. Which I'm currently asking a question to the forum into how to use the camera positions calculated from the AV_photogrammetry node
dave
dave
- tosiho19
- 46 posts
