splitPointsByVertexAttributes with Packed geometry
   5159   0   1
Hi, I'm having some issues marshalling data from an HDA that has packed geometry as its output. I use HAPI_CookOptions.splitPointsByVertexAttributes = true, which works perfectly for unpacked geometry. However, when the part is packed and I query the P (N, uv, …) attributes I get as many Points as there are Vertices.
I have test geometry: cube with 8 points with some of them having different vertex attribute values, so I expect 14 point attributes (after split). This is indeed the result I get after calling HAPI_GetAttributeInfo on unpacked geometry or when I use the Vertex Split node in Houdini. But when I do the exact same thing on a Part I get from HAPI_GetInstancedPartIds I get 36 point attributes. Even when I use the Vertex Split node before packing the geometry in Houdini I still get 36 point attributes.
If I set splitPointsByVertexAttributes field set to false I get 8 points for both packed and unpacked geometry, which is expected.
Am I doing something wrong here? Should the splitPointsByVertexAttributes work for packed geometry too? I am using Houdini 18.0.460.
Thanks,
Vincent
Edited by Vinc45678 - Oct. 26, 2020 13:01:42
packed_merged_primitives_test.hda (9.2 KB)
