Axiom Solver high res FLICKERING issue
   5595   2   1
Hi guys I have been trying out Axiom solver and I ran into a flickering issue that I am not sure how to solve.
I am using Axiom 2 in a Trial Mode.
Here in the video it's perfectly shown what is happening, basically any higher resolution setting is having apparent flickering in the sim and if I lower the resolution, same settings, same sim, it seems to work just fine. I updated drivers on my RTX 2080 GPU, I tried different shaders or tested if it's a viewport issue, tried every setting within the plugin and a lot of substeps settings but nothing solves it.
Any idea on what might be going on ?
Thank you
https://youtu.be/LyYwC2Se2Uw [youtu.be]
Edited by Nikodim Fomich - Jan. 4, 2022 16:08:07
Did you solve this? I'm having a similar problem when the smokes starts to fade out, it kinds of pop out
Trial mode has a watermark baked into the output VDBs. That would be the flickering you are seeing. When trial mode is disabled the VDBs are not watermarked.
Edited by MattPuchala - June 24, 2022 11:19:11
Matt Puchala
www.mattpuchala.com
