Different meaning of vellum
   1652   1   0
How in Houdini (for example, a flower) to set different values of vellum to different objects? I'm trying to do it through - I set the group to the leaves, set the group to the stem and sequentially connect the vellums, but the result is not even right yet. Am I doing it right or do I need to do it differently?
Hi Starikovda,
You can make a primitive group per leaf and then a clothconstraint node for each different setting.
in the cloth constraint setting point to the group. See attachment.
Ritchy
