PDGDeadline render fails with python error
   5109   2   1
when i submit a PDGDeadline Job using Houdini 19.5.368, i'm getting this error and render fails. any help plese ?
deadline version: 10.2.0.10
Error
Error: FailRenderException : PDGDeadline exception: Traceback (most recent call last):
File "C:\ProgramData\Thinkbox\Deadline10\workers\ART-WORKSTATION\plugins\63b301bd587650a3eb0a31e1\PDGDeadline.py", line 366, in RenderTasks
self.RunManagedProcess(self.wProcess)
FailRenderException: FileNotFoundError: The system cannot find the file specified
at Deadline.Plugins.DeadlinePlugin.FailRender(String message)
at Deadline.Plugins.DeadlinePlugin.FailRender(String message) (Python.Runtime.PythonException)
File "C:\ProgramData\Thinkbox\Deadline10\workers\ART-WORKSTATION\plugins\63b301bd587650a3eb0a31e1\PDGDeadline.py", line 377, in RenderTasks
self.FailRender('PDGDeadline exception: {}'.format(traceback.format_exc(1)))
at Python.Runtime.Dispatcher.Dispatch(ArrayList args)
at __FranticX_GenericDelegate0Dispatcher.Invoke()
at Deadline.Plugins.DeadlinePlugin.RenderTasks()
at Deadline.Plugins.DeadlinePlugin.DoRenderTasks()
at Deadline.Plugins.PluginWrapper.RenderTasks(Task task, String& outMessage, AbortLevel& abortLevel)
Type
RenderPluginException
Stack Trace
at Deadline.Plugins.SandboxedPlugin.d(DeadlineMessage bgo, CancellationToken bgp)
at Deadline.Plugins.SandboxedPlugin.RenderTask(Task task, CancellationToken cancellationToken)
at Deadline.Slaves.SlaveRenderThread.c(TaskLogWriter ajt, CancellationToken aju)
Log
2023-01-02 21:45:11: 0: Start Job timeout is disabled.
2023-01-02 21:45:11: 0: Task timeout is disabled.
2023-01-02 21:45:11: 0: Plugin rendering frame(s): 9
2023-01-02 21:45:11: 0: Executing plugin command of type 'Render Task'
2023-01-02 21:45:11: 0: INFO: StartFrame: 9
2023-01-02 21:45:11: 0: INFO: Startup Directory: W:/HOUDINI/pdgtemp/29864
2023-01-02 21:45:11: 0: INFO: Looking for task file: W:/HOUDINI/pdgtemp/29864/job_a77a3a9d1dc9498c94a6eaf1b352d997\task_9.txt
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RPC_TIMEOUT to 4
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RPC_MAX_BACKOFF to 2
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_HTTP_PORT to
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_SCRIPTDIR to W:/HOUDINI/pdgtemp/29864/scripts
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PYTHON_VERSION_MAJOR to 3
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_BATCH_POLL_DELAY to 2
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PATH to C:/Program Files/Nuke13.0v2
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RPC_IGNORE_ERRORS to 0
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_DIR to W:/HOUDINI
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable HOUDINI_MAXTHREADS to 0
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RESULT_CLIENT_ID to 353ebb1a75e84fe9bd871a5fdcd8d80e
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_SHARED_TEMP to W:/HOUDINI/pdgtemp/29864
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_NUKEPY to C:/Program Files/Nuke13.0v2/python.exe
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_DISABLE_TIMESTAMPS to 1
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_USE_PDGNET to 1
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RPC_RETRIES to 2
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_PATHMAP to {"version":2,"paths":}
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable HOUDINI_PATH to W:/HOUDINI/pdgtemp/29864;&
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_TEMP to W:/HOUDINI/pdgtemp/29864
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RESULT_SERVER to
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_BREAKAWAY_FROM_JOB to 1
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_JOBID to DL_JOB_ID
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_JOBID_VAR to PDG_JOBID
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RELEASE_SLOT_ON_POLL to 0
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_HFS to C:/PROGRA~1/SIDEEF~1/HOUDIN~1.368
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_DELOCALIZE to 0
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_JOBUSE_PDGNET to 1
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_MQ_CONN_FILE to W:/HOUDINI/pdgtemp/29864/job_a77a3a9d1dc9498c94a6eaf1b352d997/pdgmq_server.txt
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_PYATTRIB_LOADER to
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PYTHON_VERSION_MINOR to 9
2023-01-02 21:45:11: 0: INFO: Changing work item PATH C:/Program Files/Nuke13.0v2 to C:/Program Files/Nuke13.0v2
2023-01-02 21:45:11: 0: INFO: Setting work item PATH with HFS: C:/Program Files/Nuke13.0v2;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.368/bin
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PATH to C:/Program Files/Nuke13.0v2;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.368/bin
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PYTHON to
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable HHP to C:/PROGRA~1/SIDEEF~1/HOUDIN~1.368/houdini/python3.9libs
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_JOBID to 63b301bd587650a3eb0a31e1
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_JOB_BATCH_NAME to PDG for_PDG 2023-01-02 21:39:30.054859
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_ITEM_NAME to nukeserver_begin2_532
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_INDEX to 51
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_ITEM_ID to 532
2023-01-02 21:45:11: 0: INFO: Submit as job: False
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_SUBMIT_AS_JOB to False
2023-01-02 21:45:11: 0: INFO: Waiting for MQ connection file W:/HOUDINI/pdgtemp/29864/job_a77a3a9d1dc9498c94a6eaf1b352d997/pdgmq_server.txt
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_RESULT_SERVER to 192.168.1.2:63949
2023-01-02 21:45:11: 0: INFO: PDG_RESULT_SERVER: 192.168.1.2:63949
2023-01-02 21:45:11: 0: INFO: Setting Process Environment Variable PDG_HTTP_PORT to 63950
2023-01-02 21:45:11: 0: INFO: PDG_HTTP_PORT: 63950
2023-01-02 21:45:11: 0: INFO: Task Executable: C:\Program Files\Side Effects Software\Houdini 19.5.368\python39\python.exe
2023-01-02 21:45:11: 0: INFO: Task Arguments: "W:/HOUDINI/pdgtemp/29864/scripts/sharedserver.py" "--start" "--name" "nukeserver_begin2_532" "--port" "0" "--timeout" "30" "$PDG_NUKEPY" "W:/HOUDINI/pdgtemp/29864/scripts/nukerpc.py" "--host" "{host}" "--port" "{port}" "--log" "{log}" "--connectionfile" "{connectionfile}"
2023-01-02 21:45:11: 0: INFO: Invoking: Run Managed Process
2023-01-02 21:45:11: 0: INFO: Stdout Redirection Enabled: True
2023-01-02 21:45:11: 0: INFO: Stdout Handling Enabled: True
2023-01-02 21:45:11: 0: INFO: Popup Handling Enabled: False
2023-01-02 21:45:11: 0: INFO: Using Process Tree: True
2023-01-02 21:45:11: 0: INFO: Hiding DOS Window: True
2023-01-02 21:45:11: 0: INFO: Creating New Console: False
2023-01-02 21:45:11: 0: INFO: Running as user: ART_WORKSTATION
2023-01-02 21:45:11: 0: INFO: Executable: "C:\Program Files\Side Effects Software\Houdini 19.5.368\python39\python.exe"
2023-01-02 21:45:11: 0: INFO: Argument: "W:/HOUDINI/pdgtemp/29864/scripts/sharedserver.py" "--start" "--name" "nukeserver_begin2_532" "--port" "0" "--timeout" "30" "$PDG_NUKEPY" "W:/HOUDINI/pdgtemp/29864/scripts/nukerpc.py" "--host" "{host}" "--port" "{port}" "--log" "{log}" "--connectionfile" "{connectionfile}"
2023-01-02 21:45:11: 0: INFO: Full Command: "C:\Program Files\Side Effects Software\Houdini 19.5.368\python39\python.exe" "W:/HOUDINI/pdgtemp/29864/scripts/sharedserver.py" "--start" "--name" "nukeserver_begin2_532" "--port" "0" "--timeout" "30" "$PDG_NUKEPY" "W:/HOUDINI/pdgtemp/29864/scripts/nukerpc.py" "--host" "{host}" "--port" "{port}" "--log" "{log}" "--connectionfile" "{connectionfile}"
2023-01-02 21:45:11: 0: INFO: Startup Directory: "W:/HOUDINI/pdgtemp/29864"
2023-01-02 21:45:11: 0: INFO: Process Priority: BelowNormal
2023-01-02 21:45:11: 0: INFO: Process Affinity: default
2023-01-02 21:45:11: 0: INFO: Process is now running
2023-01-02 21:45:12: 0: STDOUT: INFO:__main__:callback_hostname: 192.168.1.2
2023-01-02 21:45:12: 0: STDOUT: INFO:__main__:Starting sharedserver : ('$PDG_NUKEPY', 'W:/HOUDINI/pdgtemp/29864/scripts/nukerpc.py', '--host', '0.0.0.0', '--port', '0', '--log', 'W:/HOUDINI/pdgtemp/29864/logs/nukeserver_begin2_532_server.log', '--connectionfile', 'W:/HOUDINI/pdgtemp/29864/nukeserver_begin2_532_connection.txt')
2023-01-02 21:45:12: 0: STDOUT: ERROR:__main__:Traceback (most recent call last):
2023-01-02 21:45:12: 0: STDOUT: File "W:\HOUDINI\pdgtemp\29864\scripts\sharedserver.py", line 466, in <module>
2023-01-02 21:45:12: 0: STDOUT: main()
2023-01-02 21:45:12: 0: STDOUT: File "W:\HOUDINI\pdgtemp\29864\scripts\sharedserver.py", line 439, in main
2023-01-02 21:45:12: 0: STDOUT: proc = startSharedServer(*servercmd)
2023-01-02 21:45:12: 0: STDOUT: File "W:\HOUDINI\pdgtemp\29864\scripts\sharedserver.py", line 101, in startSharedServer
2023-01-02 21:45:12: 0: STDOUT: proc = subprocess.Popen(argv,
2023-01-02 21:45:12: 0: STDOUT: File "C:\Program Files\Side Effects Software\Houdini 19.5.368\python39\lib\subprocess.py", line 951, in __init__
2023-01-02 21:45:12: 0: STDOUT: self._execute_child(args, executable, preexec_fn, close_fds,
2023-01-02 21:45:12: 0: STDOUT: File "C:\Program Files\Side Effects Software\Houdini 19.5.368\python39\lib\subprocess.py", line 1420, in _execute_child
2023-01-02 21:45:12: 0: STDOUT: hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
2023-01-02 21:45:12: 0: Done executing plugin command of type 'Render Task'
Details
Date: 01/02/2023 21:45:16
Frames: 9
Elapsed Time: 00:00:00:05
Job Submit Date: 01/02/2023 21:39:33
Job User: art_workstation
Average RAM Usage: 23773917184 (47%)
Peak RAM Usage: 23773917184 (47%)
Average CPU Usage: 32%
Peak CPU Usage: 36%
Used CPU Clocks (x10^6 cycles): 119152
Total CPU Clocks (x10^6 cycles): 372349
Worker Information
Worker Name: ART-WORKSTATION
Version: v10.2.0.10 Release (3b87216c7)
Operating System: Windows 10 Pro
Running As Service: No
Machine User: ART_WORKSTATION
IP Address: 192.168.1.2
CPU Architecture: x64
CPUs: 32
CPU Usage: 28%
Memory Usage: 22.1 GB / 47.9 GB (46%)
Free Disk Space: 344.071 GB
found any solution yet?
https://www.youtube.com/channel/UC4NQi8wpYUbR9wLolfHrZVA [www.youtube.com]
I had the same problem with PY3.9version; it was resolved when using PY3.7v houdini
