Texture referencing from Unreal to HDA
   3645   2   1
Hi, i'm trying to reference a single texture from unreal to my houdini hda to drive the displacement of a mesh using a triplanar displacement node.
i found on the unreal documentation the attribute "unreal_material_parameter_Texture", though im not quite sure how to implement it.
the set up i'm currently using is an exposed string parameter that I reference from an attribute create node to the triplanar texture inpu. This though doesn't seem to import the texture properly... Any help would be welcome, I'm quite new to working with houdini and unreal. Thanks in advance
houdini screenshot.JPG (20.0 KB)
houdini screenshot_2.JPG (23.4 KB)
houdini screenshot_3.JPG (23.9 KB)
Hi!
Assuming this displacement is applied to all prims.
  1. You can try setting the "unreal_material_parameter_Texture" class as detail first
  2. then get the "unreal_material_parameter_Texture" detail attribute value into displacement parm instead of referencing the string parm.
    So in Labs Triplanar Displace's Displacement parm, you could just pop in a
    detail("../soften_normals1", "unreal_material_parameter_Texture", 0)
I'm not sure if assigning an unreal texture asset path into your interface's string parm will actually modify what the referring string1 parm evaluates to through the Houdini engine, but I know for sure that asset path will show up as a detail attribute value!
If this still doesn't work, you might need to play with some python magic to evaluate the asset path to an absolute path for your texture asset.
Alternatively, you can maybe just use a Copnet to read in the texture from unreal using the same "unreal_material_parameter_Texture" attribute and then reference the texture inside your HDA.
Has anyone managed to get this working? I’m in the same situation. Right now I have to manually export displacement textures from the editor to disk so the HDA can use them. It feels kind of counter-intuitive.
In version 20.5.584 there’s still no support for translating textures: (https://www.sidefx.com/docs/houdini/unreal/inputs.html)
Using `unreal_material_parameter_Texture` seems to only return a string of the asset path.
If anyone knows a way to work around this, I’d really appreciate it!
