Groom uv parameters on vertices USD publish, vray render
   1167   0   0
We're having difficulty publishing model uv parameters on vertices, which Vray seems to need to render the groom curves from a USD file according to one of our td's. After USD publish it's attaching the UV's to points instead of vertices. Is it a correct assumption that Vray requires UV's on vertices to render from a USD publish? I understand that UV's on prims is more the standard for other render engines when rendering Houdini hair?
