Custom AOVs with Principled Shader Workflow
   1234   0   0
I was wondering what an appropriate shader workflow would be for custom AOVs (from shader not primvars) when not using MaterialX.
I can use a bind VOP to export any shader derived data when I build inside a Material Builder but is it possible to have a similar workflow as with the MaterialX dot node when making MatX shader networks outside of a builder? This isn't possible with 'bind' at that level as multiple binds with the same name have the usual issues, also it doesn't work when using the complied Principle Shader.
j
Edited by protean - June 29, 2023 06:55:41
john @ goodbyekansas
