I am a noob, at serious risk of mental breakdown. My initial excitement at the wonders the Building Generator promised was replaced by maniacal howling at the moon.
I have seen a couple of other people struggling with this in this forum and discord, but not solution has been found yet.
I am using the latest production build of Houdini Indie and Unreal Engine 5.2.1
I have followed both of Simon's tutorials (Titan project and Games Workshop) and both times I have run into the same problem which is the point cloud orientation. If before the clean node (placed after unreal input) there are a few parallel rows of the asset, after this node the result is that each asset appears to be orienting to the side: there is an outline of a square/cube, but the assets are rotated by 90 degrees.
I have repeated the project from scratch 3 times and get the same result. I am confident i have set up the pivot points correctly.
I would be very grateful for any help.
FX Labs Building Generator, cloud point rotation and madness
1940 0 0-
- thegoodtroll
- 2 posts
