Hey guys.
I use Debian 12. I just installed Houdini but whenever I try to launch Houdini, it gives this message
No OpenCL platform has the specified device type (HOUDINI_OCL_DEVICETYPE): GPU.
Falling back to built-in CPU OpenCL driver (see HOUDINI_USE_HFS_OCL)
4440: Fatal error: Segmentation fault (sent by pid 0)
I have a GTX 1080.
I saw this fix online
"However, SideFX devs got a solution for me, so if that issue occurs to anyone, try to add this environment variable to your 'houdini.env' file:
HOUDINI_USE_HFS_OCL=0
This will prevent Houdini's built-in driver (also from CPU) from conflicting with GPU drivers."
but then I can't use my GPU for AXIOM for instance. Any ideas for this?
Thanks.
Can't launch Houdini on Debian Based Linux
2418 1 0-
- nelpiper73
- 80 posts
- unixer0 Lee
- 3 posts
Hi guy, maybe i know how to fix it. I have a debian 12 system with houdini 19.5, everytime the crush happen with houdini start. error message is the same as yours, it's maybe a opencl problem, as i know, my system installed a nvidia driver v525.125.06, and NOT INSTALL CUDA TOOLKIT!so i did this:
apt install nvidia-cuda-dev nvidia-cuda-toolkit(you can find document https://wiki.debian.org/NvidiaGraphicsDrivers#Debian_12_.22Bookworm.22-1)
Restart computer, start houdini, everything working!!! i don't know why it working, maybe this action install the right OpenCL file.
Of cause, disable HOUDINI_USE_HFS_OCL=0 in houdini.env, after install cuda toolkit, don't forget this.
At last ,if you need Optix work, install it by apt install libnvoptix1
Hope this is helpful for you.
