OpenGl TOPs node doesn't render lights
   1051   2   1
Hi, I am trying to render a LOP graph using the opengl tops node. I have set the source to LOPs and I have mentioned the LOP path and camera too, it does render however there is no lighting. Am I missing something obvious or is this a bug? The lighting works fine if I do a flipbook.
This was fixed in 20.0.535, so make sure you're using at least that version.
Hello, thanks for the reply. I am using 20.0.547 and it still doesn't work. I am attaching a simple file to demonstrate the issue. It does work if I am trying to render obj context but if I try lops then the lighting doesn't work.
testOpenGl.hiplc (405.4 KB)
