OCIO Settings script error
   2872   3   2
When I try opening OCIO Settings from the edit menu I get a script error:
PyOpenColorIO.Exception: Error building YAML: Colorspace associated to the role 'color_picking', does not exist.
I tried googling for this error message but no succes.
Any suggestions?
Steven
Solved it. The culprit was a misbehaving Labs_OpenColorIO.json in the /packages folder
I removed it and that fixed it.
Nice. I had the same problem, but in my situation, that wasn't enough.
I had more than one package folder on my PC (3), and I had to find 2 of them and delete the Labs JSON file!
I overwrote the "C:\Program Files\Side Effects Software\sidefx_packages\SideFXLabs20.5\optional\labs_ocio" with default settings from houdini and worked, took me a while to figure it out, if you need, I attached below
aces_config.ocio (26.1 KB)
