Karma xpu command line rendering problem.
   1267   0   0
I've got a simple scene with several characters,some simple lights .when I render directly in hodini it's ok.when I open a windows shell type render command it still works fine.But when I render with python subprocess popen the rendering will be hanging there forever.Feek back info contains something like "Warning: Non-indexed attribute 'shop_materialpath' string found on xxxx,This may affect performance ".Dont know if it is the reason for that ,then the rendering hangs there. what does the non-indexed attribute mean? I assigned the material path using a prim wrangle writing a s@shop_materialpath attribute .please help.
Edited by spoopo - Aug. 1, 2024 13:55:41
