My Houdini 19.5 doesn't have Switch Remove Point
   1226   1   0
I don't know why my 19.5 doesn't show Switch Remove Point (juria Switch Remove Point). Can anyone explain what is wrong with this?
Thank you so much!
Because there is no node called Juria Switch Remove Point in Houdini. Whatever tutorial you're following must be using a custom HDA the instructor created. You'll have to recreate it yourself or install it if they've made it available.
