hello all..
just a topic for say that houdini to maxwell plugin is out…
it's again a beta version, but work fine for me…
i test again.. but it's really quick.
See you
Best regard
Houdini Maxwell plugin for 2.5 is available
28897 38 0- supermac
- 120 posts
- br1
- 41 posts
- supermac
- 120 posts
hello,
i don't know if it work with apprentice,
but you can find maxwell going:
render -> create render node ->maxwell render
by me i have this “node”…
I work with Houdini Master.
And you can also find node into “Network view” -> tab -> “maxwell camera” and “maxwell environment”
and also into shop node…
(Sorry for my english, tell me if you don't understood)
Best regard
Best regard
- calix
- 104 posts
- supermac
- 120 posts
- calix
- 104 posts
- supermac
- 120 posts
- calix
- 104 posts
- roughsporty
- 191 posts
- supermac
- 120 posts
- 11HP11
- 18 posts
Hi everyone,
I'm Peter, the developer of the plug-in. The current build is not compatible with 11.0.729 on OSX, so I made a new build which will be available to download today, hopefully.
The reason why the plug-in is built for daily builds: there was a bug in SOHO when the Mantra script was called instead of our script in some cases. Only workaround would have been to modify the Mantra script which we felt too risky. The bug was fixed in 11.0.707, so we released a beta version for the daily builds. Daily buids change fast and there could be compatibility issues with the new releases, but we have to live with that until a new production build is comig out. If you have any problems using the actual daily build, please let me know and I'm going to update the plug-in asap.
There's a topic on the Maxwell forum, where you can report any bugs or feature requests: http://www.maxwellrender.com/forum/viewtopic.php?f=80&t=36720 [maxwellrender.com]
But I'm going to follow this thread as well.
Regards,
Peter
Regards,
Peter
- supermac
- 120 posts
hello,
When i go on forum, i login… and i get this message: “You are not authorised to read this forum.”
I want give you bug that i seen:
1. When i modifie my material into “edit in material editor”, houdini don't take modifications..
2. if i use maxwell fire into houdini, houdini crash immediatly..
And thank you very much for this plugin, i work with and it's very fantastic..
alone problem for me, maxwell is enough slow for animation…
Think you that Maxwell will use GPU for near futur?
Thank you
See You
Aurélien
Thank you
See You
Aurélien
- roughsporty
- 191 posts
11HP11
Hi everyone,
Hi Peter, the actuall production build is now 733. You mentioned that there will be a 729 build available today. Where can I donwload the plugin?
- supermac
- 120 posts
https://portal.nextlimit.com/ [portal.nextlimit.com]
->enter your login…
->download area
->step3
->download
->enter your login…
->download area
->step3
->download
- roughsporty
- 191 posts
- br1
- 41 posts
I finally successfully installed the plugin. Somehow it was trying to install it for a version that I didn't have so I just moved the files to my current version.
Now everything loads but I cannot render as it will not render if you have an Apprentice or ApprenticeHD license. So if you' re one of those guys with an empty wallet, don' t bother installing it .
- 11HP11
- 18 posts
Hi guys,
sorry, the forum link I have posted before is accessible for beta testers only. But here is the link of the public topic: http://www.maxwellrender.com/forum/viewtopic.php?f=110&t=36736 [maxwellrender.com]
Because the plug-in uses a SOHO node, it does not work with the apprentice version, it requires a Houdini license.
The OSX build for 11.0.729 will be available within some hours, I'll be back if it's ready to download.
- 11HP11
- 18 posts
Aurélien,
could you give me some more details of the crash? You are using Windows7 64-bit, right? Which Houdini version do you try? Does it crash if you press the Render button in the ViewerPane only, or if you press the Render on the Maxwell Render ROP node?
About the “edit in material editor”. You're right, the changes in the MXM editor are not translated back to Houdini automatically right now. You have to save the mxm file, and load it in the Houdini SHOP node. I'm going to implement the automatic reload in the next release.
Peter
Peter
- supermac
- 120 posts
Hello Peter,
thank you for your help.
Yes i work on windows7
Houdini crash only when i open a windows “new floating panel” -> “new pane tab” -> “render view”
and i choose “maxwell render”…
i can see my render, but if i change anything… houdini crash
i tried with houdini build 715 and now 728
Do you understand? my english is not very good..
- 11HP11
- 18 posts
