Hello please help.
I keep getting this error I have my license. Just wont run. Any suggestions
Unable to connect to license acquistion.
Windows Xp, Geforce 2 pro 64
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Thu Nov 14 00:30:43 2002
Local host name: CANDY
Local server code: 3c9ba317
Local ip address: 127.0.0.1
License server name: candy
License server server code: 3c9ba317
Server ip address: 127.0.0.1
License server is running: Yes
Has SERVER license: Yes
License server version: 5.5.56
May modify server from this machine: Yes
License Administrator version: 5.5.56
Http proxy host: (none)
Using standalong mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
5094b4fe Generic Houdini-Master-NonCommercial 5.5 1/1 17-dec-2002
7772ca15 Generic Render-NonCommercial 5.5 1/1 17-dec-2002
139b2fee Generic Houdini-Select-NonCommercial 5.5 1/1 17-dec-2002
sesictrl -i output:
—– SERVER candy ——–
Lic 5094b4fe: 1 “Houdini-Master-NonCommercial 5.5” Generic 17-dec-2002 +.+.+.+
1 licenses free
Lic 7772ca15: 1 “Render-NonCommercial 5.5” Generic 17-dec-2002 +.+.+.+
1 licenses free
Lic 139b2fee: 1 “Houdini-Select-NonCommercial 5.5” Generic 17-dec-2002 +.+.+.+
1 licenses free
hserver -l output:
licenses file:
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 23:56:44 11/13/02
SERVER Candy 3c9ba317 aba9fefe15c68ebfb7513ef1f1c4f82b3478bb8efc6b02
# Key installed 23:59:27 11/13/02
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 17-dec-2002 +.+.+.+ \
Candy 5094b4fe 0d68bd314005ca4d98ce14c1c486414ec85e4996148f4
# Key installed 23:59:28 11/13/02
LICENSE Generic Render-NonCommercial 5.5 1 17-dec-2002 +.+.+.+ Candy \
7772ca15 ff2d2cfd8cd0401b46edb1cc303dff90ea711d4215544
# Key installed 00:01:22 11/14/02
LICENSE Generic Houdini-Select-NonCommercial 5.5 1 17-dec-2002 +.+.+.+ \
Candy 139b2fee 9a6799017f953a15008d22f63199d2b969231ac59493d
Please help on error...License Error:
12052 9 0-
- dave_h
- 3 posts
- lucas
- 269 posts
It looks like the hserver service is not running. Houdini connects to hserver which in turn connects to the license server to obtain a license. However, there is no output under
'hserver -l' in your diagnostic output, and it sounds like you're getting “Unable to connect to hserver for license acquisition” messages.
Have you tried rebooting your machine? Rebooting should restart the hserver service.
- Rune
- 5 posts
I think im having the same problem , I downloaded the Apprentice edition and the instullation went fine , the licenes seemed to work fine but evry time I try to run Houdini it wants me to install the licenes again , Im using windows xp , and i have a router but all my ports are open so i dont think that sould make a difference . I need to get that program working before the 12/1/02 when buzzs houdini course begins
- dave_h
- 3 posts
Yes I tried rebooting serveral times. Installing reinstalling. I even went as far as deleting registry keys and reinstalling. I also even deleted the services from the registry and reinstalled. I went into services and started the program still nothing.
I don't know what else I can try. I also tried renaming my comp so I can get a differnt server name to get possibly a differn't license. Still don't work.
- Rune
- 5 posts
Im using Windows XP Pro , what OS are you using ?
do you think it would work on Windows 2000 ?
do you think a router could have any thing to do with it ?
I had a problem while installing Maya on Windows XP , evry time I tryed to run it , I got an error talling me that there is a write error and then it shot down.
I think that Windows XP dosent let programs write to some folders, like the windows folder . and that the programs that need to write some temp files are geting blocked .
tell me what you think
- Rune
- 5 posts
Hey I checked it out and I found out that it is the same problem I had with Maya , The TEMP folder that is under Documents and Settings in Windows XP is not accessible to evry one , so what you need to do is to find a way to make it accessible to evry one , that meens that Houdini can write temp files to the TEMP folder .
I didnt find a way to do this , evry time I try to uncheck read-only it dosent work . If you know how to do this please let me know
- goldfarb
- 3465 posts
- オンライン
- dave_h
- 3 posts
Hey Rune,
No luck I tried to give permissions but I have Windows Xp home ed. I tried looking into enviromental variables and added a var but I don't believe it is set right. What I tried is reinstalling into my local my documents folder rather on system programs folder. Still no luck. It looks like my service client doesn't want to stay running. I tried restarting and changing the log on for the service it will start, but then it will quickly stop. So I am back at square one. I tried speaking to support but they told me to post here. So I am bit fustrated with this program. Is there any other suggestions from anyone.
- Rune
- 5 posts
- Rune
- 5 posts
Diagnostic Output:
Generated on: Sun Nov 17 14:19:09 2002
Local host name: amir
Local server code: 29dd5e13
Local ip address: 192.168.168.254
License server name: amir
License server server code: 29dd5e13
Server ip address: 192.168.168.254
License server version: 5.5.36
License Administrator version: 5.5.36
Using standalong mode: No
Installed licenses:
05ecb536 Generic Houdini-Master-NonCommercial 5.5 1/1 12-dec-2002
779b576d Generic Render-NonCommercial 5.5 1/1 12-dec-2002
648bd0fd Generic Houdini-Select-NonCommercial 5.5 1/1 17-dec-2002
097c17ba Generic Houdini-Halo-NonCommercial 5.5 1/1 12-dec-2002
sesictrl -i output:
—– SERVER amir ——–
Lic 05ecb536: 1 “Houdini-Master-NonCommercial 5.5” Generic 12-dec-2002 +.+.+.+
1 licenses free
Lic 779b576d: 1 “Render-NonCommercial 5.5” Generic 12-dec-2002 +.+.+.+
1 licenses free
Lic 648bd0fd: 1 “Houdini-Select-NonCommercial 5.5” Generic 17-dec-2002 +.+.+.+
1 licenses free
Lic 097c17ba: 1 “Houdini-Halo-NonCommercial 5.5” Generic 12-dec-2002 +.+.+.+
1 licenses free
hserver -l output:
Hostname: amir
Uptime: 0:01:48
License Server: amir
Server Version: sesinetd5.5.36
Version: Houdini5.5.36
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
130 of 383 Mb available
CPU Usage: 28% load
0 active tasks (1 slots)
licenses file:
# M5V 3E7
# Key installed 11:33:04 11/11/02
SERVER amir 29dd5e13 0eec75f759e96732b5d903405e89a308155640865042b1
# Key installed 11:33:05 11/11/02
LICENSE Generic Render-NonCommercial 5.5 1 12-dec-2002 +.+.+.+ amir \
779b576d 73098c5b92c18a1b7925a3e718ffc9962badf6ac16cd6
# Key installed 11:33:07 11/11/02
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 12-dec-2002 +.+.+.+ amir \
05ecb536 fe2016f6257dce82b8fe6e9dfc2afc576c81898710c3a
# Key installed 11:56:54 11/11/02
LICENSE Generic Houdini-Halo-NonCommercial 5.5 1 12-dec-2002 +.+.+.+ amir \
097c17ba 975af4cac961b5bb5e34983eb4dc2d857f580c7a4a61e
# Key installed 22:28:27 11/16/02
LICENSE Generic Houdini-Select-NonCommercial 5.5 1 17-dec-2002 +.+.+.+ amir \
648bd0fd 2310713dd457d521b1080583db7d34be99557722650811
Installed licenses:
sesictrl -i output:
—– SERVER amir ——–
1 licenses free
1 licenses free
1 licenses free
1 licenses free
hserver -l output:
Hostname: amir
Uptime: 0:01:48
ReadAccess: +.+.+.*
CPU Usage: 28% load
licenses file:
# M5V 3E7
