HUGE network pane
   3039   3   1
Firstly, I'm no Houdini expert ( rank beginner is probably a bit optimistic )
When ever I perform anything that creates an isolated node in the Network view Houdini puts it w-a-a-a-a-y over there. When I expand the pane to see all contents they're barely visible, no more than a few pixels.
What's worse is, I'm convinced I've seen a reference to it somewhere but I'm hanged if I can remember where, or track it down.
Anybody got a clue?
GrahamR
No, without more specifics about how you're doing it. But you can always hit the L key (with your mouse in the network pane) to re-layout everything.
What version of Houdini are you using and are you scripting the creation of nodes ?
Rob
Gone fishing
Sorry about that!
I'm currently on H12 but H11 did it too.
Like I said, it's anything that creates an isolated Node in the Network pane.
Create a camera, create a fur node, put dynamics on a fur setup etc.
If the node goes into an existing network the position is correct.
I have tried re-installing Houdini but so I've drawn the line at system re-install.
GrahamR
