cmiVFX Martin Sawtell Directable Particles & Point Cloud
   9871   5   1
cmiVFX Releases New Houdini Point Cloud & Directable Particles Training Video For TD's
High Definition Training Videos for the Visual Effects Industry
Princeton, NJ (April 20th, 2012)‚ cmiVFX has released their newest lesson offering another glimpse into magical world of visual effects. The flows of power are often visualized with streamers of light chaotically traversing across the scene. How does one create chaos but also maintain the control a director will require? In this lesson we will teach one way this is done in a production environment. The workflow offered here is tested and proven effective within the film industry. This new, exclusive effect technique can succeed in scenarios where conventional particle control systems fail. Additionally, many lessons stop with mere particles in place. Martin Sawtell will teach you one way in which those particles may be used after the simulation is done. Martin answers the question, “Particles are simmed, now what?”. He demonstrates a typical way to pass the results of a particle effect on to the compositing team for further refinement. This courseware will give you a clear idea of what is required of a VFX professional and how excellent results are achieved under the pressure of a real deadline.
This video introduces viewers to the powerful world of VOPs within Houdini, and how it can be used to direct particles via it's point cloud features. Exploring VOPs implementations in shading & rendering, geometry and POPs it presents an entire workflow that brings them together to provide you with an intuitive way to control particles. Central to this workflow is the process of developing a “point cloud advect” Digital Asset that can be re-used in any particle system- allowing the user to push particles around with arbitrary geometry that could come from SOPs, another sim or even a Mantra render. Initially the tutorial starts slow to cater for newcomers but builds in speed to cover all aspects of the workflow in extreme detail. If you are looking for a way to gain more control over where your particles are going this talk is what you need.
Short Description
Demo Video - Vimeo [vimeo.com]
NOTICE TO VIEWERS:
(*** This lesson is intended for professionals in a production environment or for those with aspirations to be such. Structure and techniques taught herein may cause cg dabblers minor depression and headaches. ***)
Here at cmiVFX we maintain a current training library for the latest versions of popular software titles. When it comes to high end CG and VFX training, there is only once choice… cmiVFX!
Don't forget about the cmiSubscription plan! Get one today. cmiVFX launched the most affordable subscription plan in Visual FX Training History for only $399 USD, and if you were a subscriber, this New Training Release would already be in your account. This video is also available a-la-cart in our brand new HTML5 player system.
|||||||||||||||||||||| HOUDINI POINT CLOUDS & Directable PARTICLES ||||||||||||||||||||||
http://www.cmivfx.com/tutorials/view/460/Houdini+Directable+Particles [cmivfx.com]
Chapter Descriptions
[imageshack.us]
Half of any particle system is it's Emitter! In this segment a novel way to generate source points is presented- using mantra to write a point cloud using a noise pattern in a shader (which is in turn reading in sops geometry as a point-cloud). The chapter also covers the basic task of setting up the guide curves that the particles will follow later. If you are new to the concept of VOPs, point clouds, and their implementation in Houdini via the geometry and shading contexts this provides a good introduction.
[imageshack.us]
Particle Tendrils
Getting on to the fun stuff (particles) this chapter introduces POP VOPs and how they can be used to open a point cloud and then advect particles based on variables like their distance from the sampled geometry and it's control attributes. It also shows how to generate useful vectors on the geometry for pushing the particles around, combining the vectors, troubleshooting the process and setting it up for re-use in other particle sims. By following the tweaking process a workflow is beginning to emerge which you can apply to many problems that require directable particles.
[imageshack.us]
Building Tools And Adding Features
So you now have a cool way to push particles around… So what? Time to turn it into a tool, that's what. Building a nice interface, writing to an OTL (digital asset) and taking into consideration that other people/houdini sessions might be using the asset while you are editing it are all covered. The particles are also further tweaked to bring in some nice noise (as a feature on the tool and separately on the geometry) plus a suction funnel is added to drag the particles into the end of the teapot.
Simming And Render Settings
In theory and motion the particles look good, but that's only in the viewport. A practical method for splitting the sim up for distribution using python is presented, as well as shading, lighting and rendering the particles with AOVs that Nuke will be able to read. It's not difficult to give nuke an EXR that has the particle's age, each light and other shading variables encoded in different image planes. While rendering and comping the particles isn't the focus of this entire lesson it's worth showing some common methods for getting what you need later into nuke.
[imageshack.us]
Application
So we've covered the workflow in a linear, detailed fashion so far but it's worth branching out and demonstrating different applications of the tool and related VOPs workflows. A very quick and dirty video that aims to give you a starting point and inspire you to do things like flow particles over a surface, use VOPs to define forces in a FLIP sim, advect particles with a pyro sim and naturally make some cool noised motion. At the end of this sequence of videos you'll have the know-how to build your own tool that can write velocity/force, position, and arbitrary attribute modifications to particles, geometry, shaders and fluids, unleashing in your mind the possibilities that VOPs and VEX offers in Houdini. Once you see the possibilities you will lose sleep.
About The Author
Martin Sawtell begun his Houdini wanderings as an intern at SideFX Software; in the past he's worked as a production designer, VJ at large scale music festivals, lecturer at university and college and as an FX TD at studios such as Framestore and DrD. He currently lives and works in Beijing at BaseFX. After a long week of production he sometimes has trouble at parties talking about anything other than particle systems and render farm politics.
Project Contents
All cmiVFX videos come with all the training materials you can need right from our website. No matter what time of day, your location, or how your feeling, cmiVFX will be there waiting for you!
This video is available today at the cmiVFX Store [store.cmivfx.com]:
About cmiVFX
cmiVFX is the leader in High Definition Video Training for the Visual Effects Community. Register for FREE and receive hours of FREE content at the cmiVFX Video-on-Demand Player. ( http://store.cmivfx.com/login [store.cmivfx.com] ) For additional information about cmiVFX, visit www.cmivfx.com [cmivfx.com].
© 2012 cmiVFX | cmiStudios. All rights reserved
オンライン
nice one Martin!
Training Lead
www.sidefx.com
good on ya
Stephen Tucker
VFXTD
Sounds like a very interesting tutorial, however is that kind of condescending tone really necessary? Best regards,
Fabian
NOTICE TO VIEWERS:
…however is that kind of condescending tone really necessary?
I don't think it condescension, it's really just telling people with less experience, in a tactful, i.e. humorous way, that the concepts and pace of the training would be difficult to follow.
Hi guys! Thanks for the support, these videos are meant to show my workflow for smushing particles around with vectors sampled from geometry via a pcopen. There's also a section on generating a particle source from PCwrite in mantra, but that's more of a tertiary thing.
Yeah they would probably be a bit crazy for someone completely new to Houdini, but I explain it in a very detailed way (3 hrs of talking woo). So it's still possible to get through it with minimal experience, but probably not easy.
-M
