What happened to shortcut “e” in VEX to enable/disable drop on wire ?
I miss it
cheers and thx for awesome release
Drop on wire in VEX - gone?
3063 3 2- tas3d
- 120 posts
- animatrix_
- 4536 posts
It works in 12.5.353.
- old_school
- 2540 posts
The drop-on-wire hotkey was removed.
You can put it back to the default E hotkey using the hotkey manager.
Easiest way is to RMB in a network view to get the options menu, find the drop on wire short cut, hold down CTRL-ALT-SHIFT and select the option to pop the hotkey manager open on this entry. Then press the field twice and type e then accept.
- animatrix_
- 4536 posts
That's why my hotkey worked then, as I use Ctrl+E (:
I use E for Foreach SOP, and other ops in other contexts.
