Problem with mats in tutor 02
5298
8
1
- hudmike
- 73 posts
Cant understand about random colors on instances mats…(((
Inside “bricks” all ok
teapot.hip (2.4 MB)
briks.otl (96.2 KB)
What don't you understand.Please be a bit more descriptive
Regards
Rob
Gone fishing
- hudmike
- 73 posts
i cant assign random color as they say in tutorial.
Good on last copy-node, but no on instance
Set the colour sop to random and by pass the material sop , make sure in the copy sop your transferring the attributes from the point to the copies.
Rob
Gone fishing
- hudmike
- 73 posts
circusmonkey
but “copy” use only for viewport.
real mesh for render created by instance from material node. how update individual colors of instances mat?
- mawi
- 242 posts
In the material1 node set the “attributes” parameter to “point attributes”.
*Edit…
If you haven´t seen it, look at the “points from volume” SOP.
Edited by - 2013年5月1日 15:03:18
- hudmike
- 73 posts
already have it
- mawi
- 242 posts
hudmike
already have it
Ok. Then you will have to upload a new file. The one a few posts up is set to primitives and switching it points gives me random colors in render.
- hudmike
- 73 posts
understood
I probably got confused in viewport visualization of instance. In tutors was h11. H12 already set view instance ON.
