Are there any ways that we can use H 11,
I have tremendous problems in using H12 to work on my files done in H 11,
I believe there are serious problem in comparability between H 11 and H 12.
Can any one help me.
Sidefx blocked using all the previous versions.
H 11
5202 12 2- aplink
- 365 posts
- Doudini
- 333 posts
- aplink
- 365 posts
- Doudini
- 333 posts
that is weird. :roll:
not sure why it wont work for you.. i just tested it and it downloads fine here.
Which browser/os are you using?
here the direct links:
windows:
ftp://ftp.sidefx.com/public/Houdini11.1/houdini-11.1.latest-win64.exe
mac:
ftp://ftp.sidefx.com/public/Houdini11.1/houdini-11.1.latest-macosx_x86_64_gcc4.2_10.7.dmg
linux:
ftp://ftp.sidefx.com/public/Houdini11.1/houdini-11.1.latest-linux_x86_64_gcc4.4.tar.gz
you can also try in the command line with wget <link> or some ftp client. and connect to ftp.sidefx.com
also you might try to “ping ftp.sidefx.com” in the command line and see if you get a reply at all. else you might need to send an email to support and ask them.
windows:
mac:
linux:
- aplink
- 365 posts
- aplink
- 365 posts
- old_school
- 2540 posts
- aplink
- 365 posts
- aplink
- 365 posts
- ben simons
- 387 posts
here's a quick guess.
Run “HKey” (the Houdini License Admin Tool) and take a careful look at the output from View->Diagnostic Information option. Does it say you are using the locally embedded license validator, or hserver/sesinetd? You might need to change it to be local. Depending on which Operating System you're using, this can be changed manually by editing a txtfile (via Houdini Shell) called
$HFS/houdini/Licensing.opt
If you have:
licensingMode = sesinetd
try commenting-it-out & changing it to:
# licensingMode = sesinetd
licensingMode = localValidator
not sure this will solve the issue; it's just a suggestion.
be prepared to undo this mod!
cheers,
ben.
If you have:
cheers,
ben.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
- aplink
- 365 posts
- aplink
- 365 posts
- aplink
- 365 posts
I tried it But, it did not work.
I attached my H11 Diagnostic Info.
Can you review and help me further please?
Thank you
Steve
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Mon Sep 2 16:13:18 2013
Local host name: yhkflys-MacBook-Pro.local
Local server code: bc202a09
Local ip address: 127.0.0.1
Number of servers: 1
License server name: new-host-2.home (new-host-2.home)
Server ip address: (could not look up server)
Reported host name: (unknown)
Reported host ip address: (unknown)
License server is running: No
License Administrator version: 11.1.388
Http proxy host: (none)
Licensing options file: /Library/Frameworks/Houdini.framework/Versions/11.1.388/Resources/houdini/Licensing.opt
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] No (ERROR: Could not connect to license.sidefx.com:80
(Are you connected to the internet? Do you
need to set an http proxy?))
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
Cannot connect to server new-host-2.home (240.41.15.0)- verify that sesinetd is running.
hserver -l output:
Hostname: yhkflys-MacBook-Pro.local
Uptime: 0:01:27
License Server: new-host-2.home
**WARNING**: Unable to contact license server (for 86 seconds)
Server Version: sesinetd4.x
Version: Houdini11.1.388
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
2,901,260 of 4,194,304 MB available
CPU Usage: 9% load
0 active tasks (2 slots)
licenses file:
* The local machine is not the server machine, so the licenses file
cannot be shown. *
Thank you
Steve
Diagnostic Output:
Installed licenses:
sesictrl -i output:
hserver -l output:
Uptime: 0:01:27
ReadAccess: +.+.+.*
CPU Usage: 9% load
licenses file:
cannot be shown. *
