Vexpressions problem in popforce
   2883   2   0
I have a popforce , I want to use this VEXpression:
if (@nage > 0.1) {
amp = 10;
but It´s doesn´t work.
Does Anyone knows where the mistake is?
Thank you.
Houdini adept
It's working but are you sure particles are reaching 0.1 of their life? Default is 100 seconds, which would be 10 seconds in your case. If you are using 240 frames @ 24fps, then you wouldn't see this change in your time frame.
Thanks It´s works.
Houdini adept
