request: explicitly reference python 2.7 in OS X
6795 6 2-
- cgbeige
- 99 posts
I use Python 3.3 as my default python install in OS X for use with multithreaded Automator actions and this breaks Houdini installation. It took me a while to figure out the problem so I'm wondering if you could make an explicit reference to /usr/bin/python2.7 instead of just /usr/bin/python , which is where I think the problem is.
- hanton
- 36 posts
you could install macport in your mac, and use
sudo port select –set python pythonXX (MacPorts 2.x)
sudo python_select pythonXX (MacPorts 1.x)
to set the python version explicitly.
http://superuser.com/questions/35256/how-can-i-change-the-default-python-version-on-snow-leopard#35288 [superuser.com]
- rvinluan
- 1259 posts
Houdini does not support Python 2.7 so you're stuck with using 2.6 or 2.5.
You can install older Python versions as suggested by hanton or download them straight from the Python website:
http://www.python.org/download/releases/2.6/ [python.org]
Rob
Rob
- rvinluan
- 1259 posts
- anon_user_37409885
- 4189 posts
- rvinluan
- 1259 posts
MartybNz
Does setting any of these 3 environmental variables help?
HOUDINI_PYTHON_VERSION, HOUDINI_PYTHON_LIB, HOUDINI_PYTHON_BIN
Houdini on OSX respects $HOUDINI_PYTHON_VERSION and $HOUDINI_PYTHON_LIB so you should be able to set either HOUDINI_PYTHON_VERSION=2.6 or HOUDINI_PYTHON_LIB=/System/Library/Frameworks/Python.framework/Versions/2.6/Python to force Houdini to use a particular Python version.
Note though that Python 2.7 is still not supported by Houdini.
Rob
- cgbeige
- 99 posts
